Four lights, ABS
Old Nov 10, 2021 | 10:37 AM
redrover75's Avatar
Default Four lights, ABS
So, plugged in a new abs pump, the electrical connections only and left the fluid lines connected. ran it a few times and the four abs lights were off. Thought I had my problem sorted, so I plumed in the brake lines and did the full swap. The lights are BACK!. I am losing my mind on this. ABS amigo give the below. Any ideas on where to look next?
I did have the Option B done on the original one and the green wire was likely loose, in hindsight may have been the cause of my issue. When I installed the new one, spliced that wire back together.
Logged Faults:
033:Front Left out valve open circuit
035:Rear Right out valve open circuit
<-END Faults
Old Nov 10, 2021 | 04:29 PM
matt3502's Avatar
You might think about doing a full fluid flush to get out all the air? I've always done my brake bleeds with a buddy helping out to make sure we get all the air out.
Old Nov 10, 2021 | 04:58 PM
redrover75's Avatar
I plan on doing that, but not sure that affects the four amigos, does it?
Old Nov 11, 2021 | 09:43 AM
matt3502's Avatar
Air in the brake lines is never a good thing. I'm not 100% sure if it will cure your codes.
Old Nov 12, 2021 | 07:15 AM
redrover75's Avatar
Default Gone
Funny, today the lights are gone.
Who knows. Going to hope it stays that way.
But now I have a couple codes,
P1590 and P1415, which have been going for while. But in the absence of the four amigos, are now getting some attention.
The guy that pinned my cylinders thinks the P1415 is due to the valve next to the purge valve, the Hyundai valve. I forget what it is called, need to do some more work on it.
The P1590 is a brake code, hoping that goes away with the Amigos.
Old Nov 12, 2021 | 09:57 AM
mollusc's Avatar
P1590 is a generic trouble code. A lot of things can cause it -- not just brakes. Sometimes it's a flaky wheel sensor.
kman3786
Jan 26, 2014 08:11 AM
SDinDS
Aug 27, 2010 07:32 PM
anorvik
Jul 13, 2010 08:41 PM
Different Drummer
Aug 7, 2006 09:28 AM
