Does the 3 Amigos prevent going into low range?
Old Nov 12, 2021 | 09:39 AM
Brandon318's Avatar
Default Does the 3 Amigos prevent going into low range?
On the 2004, low range and the shift into it worked great, then the three amigos because of a bad hub (have the new one just haven't had time throw it on yet) and now it doesn't shift into low. I checked that the solenoid is able to move. And yeah, smooth as can be, not seized at all. My only thought was that maybe the 3 amigos might prevent this? IDK. CDL engages perfectly smooth still FWIW.
Old Nov 12, 2021 | 10:33 AM
Richard Gallant's Avatar
It should still go into low and CDL lock, mine did the 2 times I had issues
Old Nov 12, 2021 | 11:21 AM
whowa004's Avatar
No issue on my 99. had the 3 amigos for years and never a problem. I do run the d1 shifter set up however. Shouldn't matter though.
Old Nov 12, 2021 | 12:30 PM
Best4x4's Avatar
ABS faults & 4Hi/N/4Lo function are not related. Probably interlock solenoid or rusty frozen cable.
Anthony Brancato
May 12, 2021 07:57 AM
Bodeanjt
Nov 26, 2019 08:46 PM
ImQuattro
Jul 11, 2014 03:57 PM
GadgetRick
Feb 9, 2012 10:18 PM
PaBs00disccovery
Sep 25, 2011 08:12 AM
