front axle advice continued
Old Sep 22, 2013 | 04:28 PM
FlyingZebra34's Avatar
Default front axle advice continued
Replacing upper and lower ball joints plus axle seals because they're worn and leaking. I have everything torn down
Q1 : what kind of grease do you use for the wheel speed sensors? I pulled them from the hub and feel like they should be cleaned.
Q2 : my diff fluid (85-140) turned into silver paint. I'm running 31"s and this keeps happening. I'm not mudding or riding too hard. Wth?
Old Sep 22, 2013 | 05:15 PM
Silver paint - Bad sign, can't make it grow back with snake oil. While diffs can be rebuilt, you might also find some at the big boneyards near you.
Also how hard do you have to pound on the steering knuckle to get it to drop?
Old Sep 22, 2013 | 05:16 PM
I replaced the rear diff 10 months ago and it happened again?
Old Sep 22, 2013 | 07:36 PM
Ok I have a splitter on here, took a blow torch to it and I'm pounding it with a sledge. I don't get it.
cationmoted
Oct 19, 2012 07:39 AM
bitter356
Jul 17, 2008 09:16 PM
Camdisco24
May 15, 2008 07:41 AM
fitch11
Feb 18, 2008 05:56 PM
audiurq
Feb 15, 2007 03:42 PM
