Front Blower Motors Not Working
Old Mar 24, 2014 | 10:51 PM
Jeremy Nicholson's Avatar
Default Front Blower Motors Not Working
I have a 2000 Disco II that has an issue with the front blower motors. Neither the heat nor the A/C blowers work. That being said, if I set the temperature to the lowest point, cold air seeps through the vents. If I set the temperature to the highest point, hot air seeps through. The faster I go, the more air moves through the vents. Revving the engine doesn't produce the same effect. The fuses are good. What should I look at next? The switch itself? A relay? I need a little guidance.
At the same time, the fuse for the heated seats/vanity lights has started to fail occasionally. What's the most likely cause? I assume I have a short somewhere and I'm hoping it's not in one of the seat heaters.
Old Mar 25, 2014 | 07:42 AM
russburcham's Avatar
Same thing happened to mine- Bad Blower Motor- You can pick a new one up on ebay pretty cheap- very simple to replace
good luck
Old Mar 25, 2014 | 07:45 AM
drowssap's Avatar
personally; i would check the ONE fan motor for power, it is located below the glove box. remove the plastic trim panel, find the blower motor unplug it and stick a test light into it. but im kind of old skoll
Old Mar 25, 2014 | 09:45 AM
remac's Avatar
I had the same problem. Drop the glove box and jump power to the fan and see if it works if it does check and see if you are getting anything out of the relay when you turn the fan on. Turned out on mine that the fan was good and the relay was good too. Problem was I was only getting switched power to the relay no constant 12v from the pannel under the hood. I ran a wire out to the fuse panel under the hood, added a fusable link, hooked it up and it works fine now. I read somewhere that the fuse panel under the hood can potentially fail. I did not want to go through the hassle of finding the bad spot and fixing it so fixed it like I said. Has caused no issue with draining my battery or anything.
Old Mar 25, 2014 | 11:04 AM
DiscoJ's Avatar
I too had the same issue, except with mine the colprit ended up being a fried wire connector right at the fan motor, the motor itself was fine. It was easily identified once I looked at it and easily repaired.
Good luck!
tsuyoi
Sep 22, 2020 10:37 AM
baddiscoII
Oct 21, 2012 05:39 AM
chermecz
Aug 9, 2012 10:02 PM
imnappraiser
Aug 27, 2009 12:16 PM
englc
Jun 4, 2008 05:43 PM
