Front Brake Noise
Front Brake Noise
My 04 D2 seems to have some brake squeal from the front brakes. I changed the rotors and pads 15k miles ago. Do they need to be changed again? I usually get about 30k miles out of new pads alone so I am very surprised that they are making noise this soon. Should I re-lube the ears of the pads with copper grease?
Thanks.
Thanks.
Thanks.
Thanks.
Also look at the caliper pins. Last squeal I had needed new pins and little rubber boots. Not a bad job to do at all, and the kit is cheap from Lucky8. Comes with lube, pins and boots.
Actually, after doing the job I reckoned that just greasing the existing pins would have worked, but swapping the parts was as easy as they have to come off anyway.
DiscoCam (02-08-2016)
number9 (02-08-2016)
bradman951
04-27-2013 01:18 AM
tibyABv6
01-07-2011 06:02 AM
