Front Brake Noise
Old Feb 8, 2016 | 02:00 PM
DiscoCam's Avatar
Default Front Brake Noise
My 04 D2 seems to have some brake squeal from the front brakes. I changed the rotors and pads 15k miles ago. Do they need to be changed again? I usually get about 30k miles out of new pads alone so I am very surprised that they are making noise this soon. Should I re-lube the ears of the pads with copper grease?
Thanks.
Old Feb 8, 2016 | 02:10 PM
cappedup's Avatar
Thanks.
Could try a relube of the pads.
Also look at the caliper pins. Last squeal I had needed new pins and little rubber boots. Not a bad job to do at all, and the kit is cheap from Lucky8. Comes with lube, pins and boots.
Actually, after doing the job I reckoned that just greasing the existing pins would have worked, but swapping the parts was as easy as they have to come off anyway.
Old Feb 8, 2016 | 08:25 PM
DiscoCam's Avatar
It was the caliper pins. I put some copper grease on them and the squeak was gone. Thanks.
Old Feb 8, 2016 | 09:39 PM
cappedup's Avatar
👍 Cool.
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
tibyABv6
Jan 7, 2011 06:02 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
