front bumper mods
RE: front bumper mods
Thanks for the recommend. I have factory lamps installed - so can you just cut away up to that mount/section? man that would be pretty easy to do probably with some tin snips, it looks like its just black plastic. BTW - I cracked up the left side under the fog lamp going coming up thru a gulley. I had to tie it up because it was rubbing against the tire on the expressway but the fog lamps still work. I'll try and get under there this weekend and check it out.
Drillbit
08-17-2015 12:32 PM
