Front Cover Crank Seal Replacement Installation Tool Option
Hello All,
I wanted to share something I did when installing my new Front Cover Crank Seal on my last engine removal.
I was searching my Sockets for one large enough in diameter to fit O.D of the Crank Seal and came up with nothing.
I'd replaced the timing Gears and Chain this time around since i'd felt it was stretched more that it should have been so I had an extra Crank Timing Gear.
This Crank Timing Gear working very nicely against the surface of the Crank seal with a few taps from the hammer.
No sealant or RTV is needed on the seal install.
Good Luck on your repairs.
outdoor7or24
12-22-2014 09:31 PM
yloDiscoII
02-10-2010 10:03 PM
lipadj46
05-31-2009 05:44 PM
2003, 366, cost, crank, crankshaft, discovery, front, instructions, land, range, replace, replacement, rover, seal, tool
