Front Crank Main Seal
#21
Is he press fitting a sleeve over a groove worn crank snout that has been turned to a smaller outside diameter?
#22
#23
Sixpack577 (11-28-2019)
#24
You do not have to remove starter to lock flywheel from turning, while removing crank bolt. Just remove rubber bell housing plug, access hole for removing flex-plate bolts. Then turn crank until one of the circular holes in the flywheel appear through hole, then slip an extension with a large socket through the hole, until it bottoms against flex plate, then remove crank bolt.
Entire job takes about twenty minutes.
Brian.
Brian.
robert.juric (12-03-2019)
