front cross member
front cross member
So have been having this back and forth wit a few friends and would like to extend the opinions.
Does the front cross member need to be on or can you run your truck without it. does your answer change if you have lifted the truck along with tires bumpers etc. thanks for your thoughts.
Lots of people run without them... but I'm going to just make some spacers.
RTE sells them, but for the price.... I should be able to do my own... maybe not from aluminum, but I think some 1-by-something steel should work fine.
http://www.rte-fab.com/products?page...category_id=13
Doing the Terrafirma 2" coil/strut kit install in my driveway and now need to either 1) remove front DS or 2) remove the cross member.
Disco Mike - You say a steel bumper would provide the same stiffness? Because I have the steel bumper w/winch mount installed currently and if this is the case, I won't feel as bad removing/cutting it out.
Also, it seems I would need spacers for the cross member anyhow to get the full increase in lift or the DS will hit the cross member...
Well, Disco Mike isn't around the forum any more and frankly he doesn't have the engineering background to make that call. I pretty firmly disagree with him considering how far away the front bumper is from that cross bar on the frame.
Keep the front cross member and get or make some spacers. Like Jeff said, it also provides some good undercarriage protection and keeps you from going pogo stick and also trashing the rest of your drive train if the driveshaft fails.
I recommend getting a bolt extractor for the bolts holding it on and then getting some grade 8 bolts of the same thread size from the hardware store. Then get some 1/2" plate and make your own spacers for it. 1sq' is like $30 at Lowe's. Cut it to size with and angle grinder and then drill the holes for the bolts to slide through. Make 2 for each side and buy bolts 1" or 30mm longer than factory.
How the shaft breaks & at what speed it breaks free are much bigger factors.
