front cross member
Old Sep 18, 2017 | 12:36 PM
  #21
Best4x4's Avatar
Originally Posted by Sixpack577
Yes, it's a pain to get off, but only from corroded bolts.
Yes, it's wimpy...but so are strut tower braces.
It does not have to be heavy duty to improve ON road handling. Which is what it's designed for.
This is basically the same argument that heavy bumpers improve frame flex. Which is 99% false also. Both ends of any span can be as rigid as you like. But without bracing throughout the span, it still flexes easily. The stronger the bracing, the more rigid it will be...to a point. The 2 small crossmembers do more in their stock location, than one twice as thick as both of them in the center.
As said, this is for on-road driving, cornering, body roll.
They work, and do what they are designed to do.
If you don't want to run them, no the truck won't collapse, and it's yours to drive however you like.
But opinions don't change facts, it is simple engineering.
It serves a purpose, but I drive my LR's on/off road, and never felt any difference. If you want a LR to corner grab one with ACE.
I do all my own maintenance on all my LR's and I'm not even in an area with corrosion. The OEM bolts are extremely soft.
However my D2's are lifted and with the member in place the front drive shaft will rest on it. What height I gained by the lift will further protect my undercarriage. Slap on the $$$ spacer & you're back to the stock height.
If I wanted awesome handling I'd be driving a late Pontiac/Holden GTO or a BMW M3.
Old Sep 18, 2017 | 01:07 PM
  #22
Alex_M's Avatar
Originally Posted by Best4x4
Back when I had Jeep's drive shafts exploding was actually pretty common (cheaper than a D2 front shaft....). Some guys had full body skids which prevented the shaft from dropping & boy what a nice surprise was hidden under there vs the guys without any type of skid.
Most of the D2 shafts I've seen explode at the double cardon side, so it "should" fall to the ground and then spun by the front diff, but of coarse it's going to rotate on it's way down. It's not going to lift the vehicle up like it would if the front u-joint broke as yep that'll drop and dig into the ground big time!
Sucks either way lol, but I wish I had taken pics of the diaster I worked on. It was almost as bad as a friend back in my Jeep days that flat towed his LJ, but the TC popped into gear exploding everything at 70-75MPH. He was clueless pulling it until people flagged him down to stop. The floor was almost completely blown out, both seats were hanging by just their outer bolts, transfer case was hanging by what was left of the linkage, case was blown apart, front shaft took out the oil pan, exhaust, cats, transmission was in pieces, and the rear shaft had grown down to a flat bar looking piece of steel. He damaged several vehicles behind him & his Colorado trip was over before it had even begun. It was totaled, and he never flat towed anything after that.
Holy o-f*cko, that's insane. I couldn't imaging flat towing without removing the driveshaft. I've heard horror stories, but that's probably the worst.
Old Sep 18, 2017 | 02:25 PM
  #23
Sixpack577's Avatar
I don't disagree that it isn't noticeable off road, and the extra flex probably helps it then too.
I also didn't buy a Disco expecting good handling, nor do I want an ACE pump. I hear they make a noticeable improvement, but not a want or need for me either.
My plans are for a 2" lift and 32" all terrain tires, as well as front and rear steel bumpers.
I had planned on keeping the cross member and adding a spacer. Still, it'll just be for rough trails and hill climbs, but nothing serious enough yet to gear it more towards off road than on. Something I'll drive to trails....because trailers are only for the ride home, lol!
Old Sep 18, 2017 | 04:21 PM
  #24
Best4x4's Avatar
Jeep actually brags about their flat towing abilities to RV owners if you can believe it or not.. My friend had done it for years before his disaster, but it just goes to show how something as simple as hitting a pothole can cause a 100% mechanical linkage to hop into gear from N.
I read the Jeep owners manual in both my TJ/LJ & WJ and I never liked the sound of it.
Something place trans into N, move 2wd/4Hi/N/4Lo selector to N, then if an automatic place back in Park.... I'm sure I've forgotten it 95%, but I never liked the idea of flat towing without removing shafts to be safe.
Old Sep 18, 2017 | 05:39 PM
  #25
Rlozano's Avatar
I run no front crossmember and no sway bars and my Land Rover corners like a champ! I love the feel of a paddle boat entering open sea during a big storm... I call it positive steering feedback!
Old Sep 18, 2017 | 05:49 PM
  #26
Rlozano's Avatar
All seriousness though, I just tried bolting on my front cross member to see if it aligned after wheeling for 1.5 years with it off and it did perfectly. I do have the front and rear steel bumpers. I drive it 3 hours each way to wheel all over Tahoe, do heavy wheeling. I’ve put roughly 25k miles on it and the frame seems to have held up just fine. I do fall into the category of the lazy guy that didn’t make the spacers like initially intended but the rover has been fine without it.
Old Sep 18, 2017 | 06:03 PM
  #27
Sixpack577's Avatar
Good to hear, sounds like you have a good one.
Old Sep 20, 2017 | 01:55 PM
  #28
LandBeard's Avatar
Wow awesome to hear all of the input from my shot in the dark - didn't think I'd get this many responses!
It sounds like the debate is equally divided, but agrees that the cross member does provide additional stability for daily driving/structural integrity. No brainer here
Due to my schedule and location of where I leave my truck to do work, I'm mostly dreading the time it will take to extract what bolts are seized/rounded out. So, with that I'll probably see how she feels with the cross member removed and when I get a chance to pickup the materials, I'll fab the spacers. Worst case scenario my patience runs out and I'll chop the entire thing off and buy one used for ~$60 off eBay.
Old Sep 20, 2017 | 02:32 PM
  #29
OffroadFrance's Avatar
My take on the subject is that LR didn't install it for 'decoration purposes only' so invariably it has a function and is required, what for, who knows, but my attitude is keep it stock unless you're an offroader or racer and into mods and weight saving etc. IMO it is used to prevent the frame from spreading/flexing laterally around the area of the gearbox mounts but I'm merely guessing.
Twins Disco
Aug 27, 2021 05:19 PM
griffker
Nov 22, 2012 07:55 PM
agthird
Aug 18, 2010 10:15 PM
A_J
Apr 24, 2010 08:57 PM
core96
Jun 23, 2009 12:25 PM
