Front Differential Seal Leaking at Propshaft
Old Jan 7, 2014 | 12:24 PM
taylor15's Avatar
Also make sure you completely remove all of the old seal. They rip and a metal ring can get stuck in there which will cause the new one some issues.
Old Jan 7, 2014 | 12:31 PM
antichrist's Avatar
You can check the flange when you remove it. If it's not grooved or damaged on the surface that fits in the seal shaft area there's no need to replace it. Yeah, it's somewhat of a pain to do it again if you find it's grooved and can't leave the Rover out of service until you replace it and so have to remove the propshaft again, but not a huge deal. You only have to remove the diff end of the propshaft and if you've just done it, it's pretty easy. At only 103,000 miles the flange shouldn't be grooved.
If you don't need to replace it, you can put the money towards a torque wrench, which you should have anyway, if for nothing else then to torque your lug nuts correctly.
You might check at an autoparts store to see if they loan/rent torque wrenches. Or ask friends.
Old Jan 7, 2014 | 12:56 PM
Dave03S's Avatar
Or put the money toward a new serviceable front drive shaft.
Old Jan 7, 2014 | 01:06 PM
Phatrowles's Avatar
Nice! I just realized that a torque wrench isn't only the tool that is hooked up to an air compressor that they put F1 wheels on with in the pit... I will pick one up at Harbor Freight for $25. Woohoo!
mpanoussi
May 20, 2013 08:13 PM
outdoor7or24
May 21, 2012 08:34 AM
CANAMDiscovery
Apr 5, 2012 11:30 PM
yloDiscoII
Feb 10, 2010 10:03 PM
Disrover
Aug 21, 2009 09:47 PM
