Front Door Locks NOT Working?
Hi Guys,
The front door locks are not working with the key fob nor the interior unlock/lock switch. All other doors work fine. I replaced the driver side door with a known working actuator and even replaced the fuse panel and still nothing. I'm getting the horn beep once when I go to lock the car and also the red light under the binnacle flashes steady and fast when in the lock mode. Any suggestions?? Thanks!
The driver door actuator will lock if I press the lock button twice on the remote, but it won't unlock with the remote and the passenger won't do either. It's not the actuator and it's not a fuse that I can tell. Is it the BCU? Are there any relays other than in the BCU? This truck only has 71,000 miles on the odometer.
sdowling80
Feb 26, 2014 06:30 AM
dogparc
Jan 3, 2012 04:38 PM
DiscoWest
Apr 15, 2011 08:10 PM
