Front Door Locks NOT Working?
Old Jul 3, 2017 | 07:48 PM
RhinoRover's Avatar
Default Front Door Locks NOT Working?
Hi Guys,
The front door locks are not working with the key fob nor the interior unlock/lock switch. All other doors work fine. I replaced the driver side door with a known working actuator and even replaced the fuse panel and still nothing. I'm getting the horn beep once when I go to lock the car and also the red light under the binnacle flashes steady and fast when in the lock mode. Any suggestions?? Thanks!
Old Jul 3, 2017 | 07:49 PM
RhinoRover's Avatar
Should have mentioned that it's on my 2001 D2 SE. I'm trying to fix it for the buyer, so I'm kind of in a hurry!
Old Jul 3, 2017 | 10:38 PM
RhinoRover's Avatar
The driver door actuator will lock if I press the lock button twice on the remote, but it won't unlock with the remote and the passenger won't do either. It's not the actuator and it's not a fuse that I can tell. Is it the BCU? Are there any relays other than in the BCU? This truck only has 71,000 miles on the odometer.
Old Jul 3, 2017 | 11:01 PM
RhinoRover's Avatar
I was getting voltage at the lock actuator electrical connector. One of the pins would be charged with 11.7 volts when the lock/unlock button was pushed on the key remote.
focusontheworld
Dec 27, 2014 12:50 PM
dogparc
Jan 3, 2012 04:38 PM
DiscoWest
Apr 15, 2011 08:10 PM
jmerrill
May 17, 2006 01:18 AM
