Front Door Malfunction
Old May 12, 2018 | 07:23 PM
Aj6543's Avatar
Default Front Door Malfunction
My front door won't lock or open with pressing the key fob. It does however lock and open manually when I insert the key. What is wrong?
Old May 12, 2018 | 10:48 PM
redrover75's Avatar
Default Actuator
I had the same issue. Just replaced the actuator today, fixed the issue
could do it an hour, make sure that you install the exterior handle connection correctly.
Old May 13, 2018 | 08:07 AM
niceflipflop's Avatar
There's a really good step-by-step on YouTube, only the guy is replacing the passenger side. Here it is put thru a mirror flip site, which worked brilliantly for me when I replaced my driver's side: Mirror flip a YouTube video
The only caveat is that since he's doing the passenger side, he doesn't show how to do the handle linkage. But there's info out there on that piece.
Block out a few hours, take your time, and like the guy in the vid says, keep your parts organized, and you'll be fine.
Good luck.
Old May 13, 2018 | 12:03 PM
Kdo58's Avatar
I would order the heavy duty pin for the door lock while you have it apart.
Old May 13, 2018 | 07:30 PM
Aj6543's Avatar
Where can I order the heavy pin from?
Old May 13, 2018 | 08:41 PM
abran's Avatar
I have no association to the seller... cough!cough!
https://rover.ebay.com/rover/0/0/0?m...2F253212754877
jackmanmachine
LR2
Mar 12, 2014 11:46 PM
Disco23
May 11, 2008 07:49 PM
ChiefOne
Aug 19, 2007 04:18 PM
jonnymcd
Mar 22, 2007 05:24 PM
georgecy
Mar 18, 2006 04:40 PM
