Front Drive Seat not working
![](https://s6.postimg.org/puqtt146l/IMG_3542.jpg)
What is this part and where do I get a replacement.
Seat stopped going forward and backwards. When I hit the seat switch forward or backwards, I noticed this part is clicking and the long white tube looks like something is going on in it, but nothing moves.
Anyone have any experience with this?
It doesn't appear to be sold separately on the usual parts sites. Probably a used unit from a parts car/junkyard is going to be your best bet.
Have you removed it and opened it up? If there's a simple motor in there, it may be easy to find a replacement for.
Edit: it looks like this might be it, but it's expensive: http://www.rimmerbros.co.uk/Item--i-HAK100060
The white tube has a cable in it. If the cable is moving then the motor is working and you have a cable connection issue.
Is it worth pulling out the seat to just see if there is a connection issue? Is there something to look for that doesnt require pulling the seat?
It's a flexible shaft. I would pull the seat as it is easier than you probably think and will give you more room to work. The hardest part is making sure you don't scratch the interior or door jamb while removing.
Is there a high chance that it is just a cable that has popped out and not actually broken? Is this common. It would be the first time it has ever happened to me.
had the same thing happen to mine. got a replacement (used) from Paul Grant. installed it myself, works great. the install was pretty easy, although a bit tedious, but not difficult. make sure you've got the right part number. would strongly suggest a used one from one of the guys here on the forum.
tsuyoi
09-22-2020 10:37 AM
johnkbl
01-13-2009 08:54 PM
