Front Drive Seat not working
Old Jun 17, 2016 | 08:19 PM
cybercop's Avatar
Default Front Drive Seat not working
What is this part and where do I get a replacement.
Seat stopped going forward and backwards. When I hit the seat switch forward or backwards, I noticed this part is clicking and the long white tube looks like something is going on in it, but nothing moves.
Anyone have any experience with this?
Old Jun 18, 2016 | 09:08 AM
cybercop's Avatar
It seems this is called the Forward Back motor. Some research states it is part number 541152RO 1.
Is this a part I will have to get used?
Old Jun 18, 2016 | 10:45 AM
batard's Avatar
It doesn't appear to be sold separately on the usual parts sites. Probably a used unit from a parts car/junkyard is going to be your best bet.
Have you removed it and opened it up? If there's a simple motor in there, it may be easy to find a replacement for.
Edit: it looks like this might be it, but it's expensive: http://www.rimmerbros.co.uk/Item--i-HAK100060
Old Jun 18, 2016 | 11:16 AM
abran's Avatar
The white tube has a cable in it. If the cable is moving then the motor is working and you have a cable connection issue.
Old Jun 18, 2016 | 12:02 PM
cybercop's Avatar
Is it a cable or a drive shaft. I see something moving in there and thought it was a shaft that was broken.
Is it worth pulling out the seat to just see if there is a connection issue? Is there something to look for that doesnt require pulling the seat?
Old Jun 19, 2016 | 10:28 AM
abran's Avatar
It's a flexible shaft. I would pull the seat as it is easier than you probably think and will give you more room to work. The hardest part is making sure you don't scratch the interior or door jamb while removing.
Old Jul 5, 2016 | 02:15 PM
cybercop's Avatar
Ive removed the seats before, so not too scared. Just want to make sure I have everything to fix it before removing it.
Is there a high chance that it is just a cable that has popped out and not actually broken? Is this common. It would be the first time it has ever happened to me.
Old Jul 5, 2016 | 05:06 PM
jamestfl's Avatar
had the same thing happen to mine. got a replacement (used) from Paul Grant. installed it myself, works great. the install was pretty easy, although a bit tedious, but not difficult. make sure you've got the right part number. would strongly suggest a used one from one of the guys here on the forum.
Old Jul 6, 2016 | 01:59 PM
cybercop's Avatar
jamestfl, would you have the part number handy?
Old Jul 6, 2016 | 02:56 PM
jamestfl's Avatar
it looks like its part no: HAK100040. double check that though.
tsuyoi
Sep 22, 2020 10:37 AM
snowdude
Nov 30, 2008 08:12 PM
fluffdaddy
Apr 13, 2008 07:02 PM
loic
Dec 16, 2007 02:04 PM
