Front drive shaft vibration
I fixed the problem. It wasn't the drive shaft but the output flange from the t-case the the drive shaft bolts into. I just removed the drive shaft and tightened the 30mm bolt and that was it.
Daedrix, I was going to say that the front LT230 flange was wobbling around causing the shaft to oscillate. Hopefully your woes are solved but do check the front transfer box bearing and also fit a new self locking nut to the flange, you don't need that to come undone
You might also want to check the front transfer box oil seal as it may have damaged that as well.
DiscoJon
07-14-2019 01:51 PM
TripleThreat
04-12-2011 08:58 AM
