Front drive shaft vibration
Old Apr 8, 2016 | 03:41 PM
Daedrix's Avatar
Banned
Default Front drive shaft vibration
So i have had a vibration on my front end somewhere and i think i found it.
Now the question is how do i fix it?
Old Apr 8, 2016 | 04:23 PM
LR03NJ's Avatar
Looks like the vibration is coming before the shaft. Dont you think so. You can probably remove the shaft and try if the noise is still present.
Old Apr 8, 2016 | 05:24 PM
Joemamma1954's Avatar
I would remove the shaft and then see if the shaft coming out of the diff has any play or the u-joint has any. If it is in the diff then it may have to come off to replace the shaft and or bearings.
Hopefully it is the drive shaft.
Old Apr 9, 2016 | 02:16 AM
toofaroffroad's Avatar
Just fixed a vibration issue. After taking my drive shafts off and checking everything it ended up being the engine mounts. both cracked and sagging. Vibration is now fixed.
Old Apr 9, 2016 | 10:44 AM
Charlie_V's Avatar
I think is is VERY cool that you got that video with the driveshaft spinning.
Old Apr 9, 2016 | 01:05 PM
Daedrix's Avatar
Banned
Having an auto hobby shop available is a big plus when it comes to fixing my rover.
I fixed the problem. It wasn't the drive shaft but the output flange from the t-case the the drive shaft bolts into. I just removed the drive shaft and tightened the 30mm bolt and that was it.
Old Apr 9, 2016 | 03:21 PM
OffroadFrance's Avatar
Daedrix, I was going to say that the front LT230 flange was wobbling around causing the shaft to oscillate. Hopefully your woes are solved but do check the front transfer box bearing and also fit a new self locking nut to the flange, you don't need that to come undone
You might also want to check the front transfer box oil seal as it may have damaged that as well.
DiscoJon
Jul 14, 2019 01:51 PM
PanamaDisco
May 22, 2014 07:48 AM
TripleThreat
Apr 12, 2011 08:58 AM
andrewmcoffin
Nov 21, 2010 08:18 PM
brooksa
Jun 6, 2008 09:34 PM
