Front drive shafts when should they be replaced?
Old Mar 8, 2010 | 07:06 PM
hilltoppersx's Avatar
Originally Posted by Spike555
They fail because they are non serviceable.
Meaning that they cannot be greased at every oil change like all u-joints need to be.
And without proper service the grease inside them wears out.
The front driveshaft on a DII is only 2" from the passenger side catalytic converter, and it is right under the passenger side a/c drain.
So it gets the trifecta, non greaseable, water drips on it and then it gets baked by a 1000*F furnace
When it breaks, and it will, it will take out your transmission, if you are lucky that is all it does.
It can also take out your exhaust.
You can avoid all of this by having it rebuilt using greasable u-joints.
Having it done will cost about $300.
AND your transfer case.
Old Mar 9, 2010 | 08:04 AM
When you first bought it. Mine failed under hard wheeling at 37,000 miles and believe me you don't want to wait around till you punch a hole in the tranny.
If you get it rebuilt, make sure to buy American made u-joints with grease fittings and a new centering ball.
Old Mar 9, 2010 | 08:09 AM
tornado_735's Avatar
The one on my DII went at 113K.
Old Mar 22, 2010 | 12:51 PM
Danny Lee 97 Disco's Avatar
Mike, I have a 97 DI that probably has the original drive shaft. I bought it will approx 100k on it and it has about 112 now. Do you have instructions/parts list for rebuilding. Your help is sincerely appreciated.
Old Mar 22, 2010 | 02:39 PM
antichrist's Avatar
Everything you need to know but were afraid to ask.
https://landroverforums.com/forum/sh...ad.php?t=29302
Old Mar 22, 2010 | 07:29 PM
BrianK's Avatar
3rd Gear
Any trusted shops in Central Florida that will do this?
Thanks,
Brian
Old Mar 23, 2010 | 05:01 AM
Thanks,
Brian
any drive line shop should do a bang up job. just make sure you have them use the correct parts and balance it.
Old Mar 23, 2010 | 01:09 PM
Default Rebuilding Driveshaft
Mike,
After reading this thread, I am concerned with mine. I called a local salvage yard that specializes in Foreign Autos and they have a front drive shaft for $45. So I plan on grabbing it up and upgrading it to swap out with mine which is probably original. My questions are what is the Centering Ball and is there a procedure for rebuilding the drive shaft.
Is thyere a specific manufacturer or source you can reccommend for the parts?
Thanks immensely for your help to me and everyone else that writes in.
I plan on continuing to upgrade my DI and hopefully get another one as well. I am sure I will be turning to this site for guidance.
Old Mar 23, 2010 | 03:45 PM
Long Haul's Avatar
Originally Posted by Danny Lee 97 Disco
Mike,
The D1 doesnt have a centering ball. It just has a standard 2 joint drive shaft. But I would recomend replacing the factory non greasable with greasable ujoints.
Old Mar 23, 2010 | 06:10 PM
Mike,
You will get more responses is you dont specifically ask Mike for help.
If you want Mike then send him a PM.
The 1997 Discovery has 4 u-joints and they are all greasable from the factory.
ONLY the DII came with non greasable u-joints, that was one of BMW's cost saving idea's.
Grease all four of your u-joints at every oil change and you will be fine.
For piece of mind you can have your u-joints replaced.
A friend and I did all of mine last year and it cost me $50 for four u-joints from AutoZone.
If you buy a used driveshaft you will need to replace it's u-joints before you can even install it.
Any shop can replace all of yours, probably cost $100-150 to have them done.
