Front Driveshaft Issue?
Old Jun 8, 2016 | 11:53 AM
Dave03S's Avatar
Curious, how much did they charge you for the wheel alignment?
Old Jun 8, 2016 | 12:15 PM
PDX Disco II's Avatar
Originally Posted by Charlie_V
Jfall has a great suggestion. It might save a driveshaft.
I'd add... I had an odd driveshaft feel so I pulled it and locked the CDL. Smooth. But I wasn't getting a squeak. I called the shop and asked what was wrong with my still in warranty driveshaft. They said "have you greased the centering ball?". Um, no. I don't know how to do that. They laughed that "what an idiot" laugh (rightly so) and told me how to find the secret grease point. I greased it and still have the same shaft a year later. On any shaft I've ever seen (a few) the shaft has to be removed to fully articulate the centering ball and find the tiny hole for grease. You might try that as well.
I drove the truck around again yesterday... There is still some vibration that I didn't have in the past. My 03' doesn't have a CDL , but i'm going to pull the front shaft, inspect, and do an extensive grease. Did you get the special driveshaft tool (link below) or can you get away without it?
Drive Shaft Socket Wrench Tool - Land Rover Drive Shaft Tools
Old Jun 8, 2016 | 12:18 PM
Tire Factory Invoice;
- Alignment check $19.50
- Spin/Balance @ $12.25 x 4 = $49.00
The alignment needed little adjusting, so they just chalked it up to a "check," which was pretty nice.
Old Jun 8, 2016 | 02:02 PM
batard's Avatar
As I understand it, alignment doesn't have any bearing on vibration (i.e. a car can't vibrate because of bad alignment), but obviously it's always good to have it checked/fixed.
Old Jun 8, 2016 | 06:17 PM
Charlie_V's Avatar
The only tool I needed was a grease gun needle. Maybe yours is different?
Old Jun 8, 2016 | 06:57 PM
For pulling it off of the truck... Not just greasing it
Old Jun 8, 2016 | 07:32 PM
Charlie_V's Avatar
Oh sorry. I just use 9/16ths wrenches.
robert.juric
Nov 3, 2022 06:08 PM
PDX Disco II
Jun 6, 2016 02:23 PM
AaronG
Apr 1, 2012 08:00 PM
clandrovers
Oct 10, 2010 01:09 PM
jusspasd
Oct 2, 2006 01:15 PM
