Front Driveshaft Replacement - Nuts, Bolts & Procedure
Old Jun 4, 2016 | 11:36 AM
  #21
Jeff Blake's Avatar
Is this ok? The bolt is about 1/8"-1/16" inside the nut. This is OEM bolt, and the shortest 3/8-24 nut I can find
Old Jun 4, 2016 | 12:41 PM
  #22
NickAdams's Avatar
Just took a peek at mine. When I re-built the front drive shaft, I bought new nuts and bolts. The bolt length matched what I took off (no telling if they were Land Rover supplied or not.) I used nylon lock nuts like yours, but the bolt sticks out about 3/16" beyond nut.
Old Jun 4, 2016 | 12:54 PM
  #23
number9's Avatar
Most specs call for at least one thread showing.
After the nut has been tightened, make
sure the bolt or stud has at least one thread
showing past the nut.
Old Jun 4, 2016 | 01:37 PM
  #24
Jeff Blake's Avatar
Alright, well I'm leaving it for now. Turns out the flange on the Tom Woods is about 1/4" wider than the stock shaft. There's my missing threads. Anyone from lucky8 here who can comment?
Old Jun 4, 2016 | 04:39 PM
  #25
shanechevelle's Avatar
I guess when I go to the junkyard (weekly) I will start taking off the front shaft nuts and bolts...
I just found a practically brand new front shaft at the local u-pull-it for $25. Still had a very new looking sticker on it, new bolts and nuts. I looked under the truck and there was road grime and oil everywhere, but the front shaft looked beautiful.
I picked the best looking nuts and bolts and reused them. They aren't going to break.
dcarr1971
Feb 8, 2013 08:16 AM
wastedincome
Oct 16, 2012 01:21 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
ljdiscovery
Jun 26, 2010 07:44 AM
tornado_735
Mar 5, 2009 04:39 PM
