Front end vibration
Front end vibration
Ok so with the 2 inch lift and new steering components done took it down for alignment about 2 weeks ago. Well been chasing a vibration demon. Found a place to do my ball joints etc.
well today did the oil change and I found my problem. With HD steering the steering damper bracket is clamped to the rod by u bolts. In order to adjust it you have to loosen them up.
when I was removing the oil filter I grabbed the steering damper and it moved a lot.
and I found out the really mared up the rod when doing it. Wtf there are places at the end to put a wrench on it do it.
so I tighten up the damper bracket and took done a rough road with turns and everything we where feeling in the steering is gone.
grrrrr
called the place up and explained to them what I had found and after talking to them they decided to refund me the cost of the alignment.
that said and done I still have to scuff up the places and clear coat it.
grrrrr
