front engine cover question
Old Apr 18, 2011 | 09:24 PM
jck09's Avatar
Default front engine cover question
I acquired a used front cover for my block replacement project. I have an 03 with the dreaded knock so this is why im replacing the block. The block did not come with the front cover so i had to get one somewhere else. I do not have my engine out of the truck yet so Im unsure of the condition of the cover that is in here now. The "new" to me cover has some light scratches on the inside where the pump gears go and on the plate that secures the gears in place. How do I know what is acceptable as far as the scratches go? They are nowhere near gouges and can barely be felt with the finger nail. They are worse on the securing plate. Thanks
John
Old Apr 19, 2011 | 06:48 AM
Bundu's Avatar
Banned
The specs are in rave. Check and measure according to the rave specs.
Old Apr 19, 2011 | 10:17 PM
vandev's Avatar
Default me too
i would like to get a picture of a new one on the inside as well....before i buy another one...
Old Apr 20, 2011 | 08:53 AM
Did you check your oil pressure before condeming the engine? Why buy a used cover when you can just replace the pump gears?
Here is the only picture I could find of the inside of the cover.
Attached Thumbnails front engine cover question-land_rover_discovery_oil_pump_ljr000220_b.jpg
Old Apr 20, 2011 | 08:54 AM
jck09's Avatar
where at in the rave is it listed? Cant seem to find it.
Old Apr 20, 2011 | 10:56 AM
Bundu's Avatar
Banned
My apologies, it is in the V8 overhaul manual on page 22:
http://www.landroverresource.com/40_46_V8_overhaul.pdf
tmtegt
Mar 20, 2013 07:31 AM
TRIARII
Nov 4, 2012 05:30 PM
Fireman
Oct 5, 2010 05:38 PM
lipadj46
Nov 17, 2009 11:13 AM
lipadj46
Nov 15, 2009 05:59 AM
