Which Front Hubs to buy
Since I have a 2" lift and larger-than-stock tires, I might go with the more expensive hubs.
I just got a closeout front hub from Rock Auto. I had installed an eBay one, and used the old sensor that was too long, and I believe it has damaged the hub. I installed the sensor that came with the hub when the amigos came back with the sensor fault. It was the type of sensor that is spliced in the cabin, hence trying to use it with the eBay hub.
I am installing the Rock Auto hub tomorrow morning. The eBay hub I put on the driver's front side has been perfect. I just did not know the sensor was different. On the driver's side that is malfunctioning.
Brandon318
Feb 25, 2020 12:47 PM
