Front interior light not working on "ON position"
Old Oct 25, 2021 | 08:23 PM
Mufasa93's Avatar
4th Gear
Question Front interior light not working on "ON position"
Hey. my front interior light won't work on the "ON POSITION". the bulb is fine, It works perfect with the doors "switch in mid position".
I disassembled it, found a bit of grease beneath the switch on the metal part and cleaned it. Yet it didn't fix the issue.
any help would be appreciated.
Old Oct 25, 2021 | 08:26 PM
Best4x4's Avatar
Make sure the ground is connected. If it isn't the switch will act all sorts of funky
Old Oct 25, 2021 | 09:58 PM
Mufasa93's Avatar
4th Gear
Thanks for the reply.
you are right. its supposed to connect to the metal mounting bracket. but I can't find the ground connecter anywhere. I'm guessing the previous owner used it for the sunroof maybe?
the only ground I found is connected to the sunroof
Old Oct 25, 2021 | 10:04 PM
Best4x4's Avatar
I'll have to double check one of my parts trucks when I get a chance tomorrow but I don't remember the ground looking like the one on your sunroof. I think was just a naked blade connector. Been a while since I had one apart but I'll look when I get a chance for ya.
jdwilks
Aug 27, 2014 10:59 AM
wabuson
Oct 5, 2012 04:16 PM
losinov
Audio/Visual Electronics
Dec 2, 2010 07:07 PM
hillbilly hangover
May 24, 2010 05:12 PM
FJL
Jan 13, 2008 10:07 PM
