Front Left Window issues
A couple days ago all my windows were operating normally.
I took apart the middle console in an effort to ground a couple wires from the radio unit, so I had to disconnect the wires and connectors to the windows and heated seats.
Since then my front left window doesn’t work. All other buttons on that console operate and I’ve taken it apart again to check connections. Replaced the right window connector in the left window hookup and the right window operates fine with that hookup.
When I press the button with the left window connected to it nothing happens. There is zero noise, zero movement, it’s like it’s dead.
That particular window motor was replaced a year or two ago. Any ideas?
I dont follow, so you swapped the control button from left to right, and the right side works with the left button installed?
If that is the case, then you've got either a popped fuse or bad motor. Motors don't usually give any warning and just give up.
The noise you heard on other vehicles in the past was cable regulator failing
Im sure it is the motor but I swear I just saw a receipt for a new one installed not too long ago.
oaty
09-29-2018 12:30 PM
RossN99
01-27-2018 11:18 AM
Al Blue4.6l
08-14-2011 05:28 PM
