Front LH ABS Sensor Wiring Question
Old Jun 6, 2017 | 12:51 PM
CollieRover's Avatar
Default Front LH ABS Sensor Wiring Question
When wiring my front left wheel speed sensor, I routed it along the wiring harness at the back of the engine up near the cabin filter.
Has anyone done this successfully? I am getting intermittent faults from it, and I am thinking it is possible that there is electrical interference back there.
Old Jun 7, 2017 | 07:58 AM
Bump, just wanted to see if anyone had routed it this way. I will be trying to get it through the back of the dash. Hopefully, I left enough wire. Should have. Also, going to try and install the new clips to eliminate solder.
Old Jun 7, 2017 | 11:55 AM
jamestfl's Avatar
Not directly on point- I did the RH side sensor. Just twisted new wire onto existing. Was hoping for a good test / temp fix. Actually worked and have excess line coiled up and stashed to right of brake booster, near fire wall, no issues from there in over 3 months. You're getting signal failure? Re- check all work.
Old Jun 7, 2017 | 12:32 PM
i do, and have cleaned, re-seated and re-torqued the sensor. Next up is rewiring.
KlamathMatt
Apr 17, 2020 05:27 AM
colemtd
Mar 30, 2019 08:57 PM
KingKoopa
Mar 3, 2017 06:23 PM
twaszak
Jun 4, 2011 07:49 AM
