Front output seal - yes or no lube
I'm about to replace mine also. If the RAVE specifies to fit it dry, then I'll probably try to fit it dry or mostly dry at least. If it is lubed it may give to oil somewhere that it can seep out at (like after you've opened a bottle of oil). Then again, it may work better if you lube it (like an oil filter).
This is probably not helpful at all, but that's my thoughts on the deal. If it sounds wrong then you will probably have to replace it again before it breaks something else.
What page of RAVE does it state that they should be installed dry without any lube?
tskeltonPGA
01-16-2008 07:21 PM
