Front output seal - yes or no lube
Old Sep 28, 2014 | 05:47 PM
taylor15's Avatar
Default Front output seal - yes or no lube
The RAVE says to fit dry but almost every write up says to put a bit of lube on it. What do you guys think? It's difficult to get in dry and I think I damaged mine. The truck has an odd sound, almost like clapping dice together now.
Old Sep 28, 2014 | 08:55 PM
Alex_M's Avatar
I'm about to replace mine also. If the RAVE specifies to fit it dry, then I'll probably try to fit it dry or mostly dry at least. If it is lubed it may give to oil somewhere that it can seep out at (like after you've opened a bottle of oil). Then again, it may work better if you lube it (like an oil filter).
This is probably not helpful at all, but that's my thoughts on the deal. If it sounds wrong then you will probably have to replace it again before it breaks something else.
Old Sep 29, 2014 | 07:05 AM
OffroadFrance's Avatar
Which output seal are you referring to?, I am assuming it's the front transfer box seal behind the output flange to the front shaft and diff. I am about to embark on an upgrade on my transfer box and will install the seals with a mild Loctite threadlock fluid instead principally to lock them in place and also prevent possible oil leaks.
What page of RAVE does it state that they should be installed dry without any lube?
Old Sep 29, 2014 | 07:44 AM
drowssap's Avatar
they may mean to install them into the housing dry, but most seals require that they be wet on the shaft end on startup so as not to rip the dry seal.
Old Sep 29, 2014 | 10:14 AM
taylor15's Avatar
Yes, it's the front output on the transfer box. Putting it in completely dry was a task. I'll find the page number when I get home. I may grab another seal and try again and at least lube the shaft end.
Old Sep 29, 2014 | 12:34 PM
taylor15's Avatar
Old Sep 29, 2014 | 07:32 PM
taylor15's Avatar
In the rave manual it is page 41-36, step 2. Also, is it needed to add any grease to the bearing before putting the seal back in?
Old Sep 29, 2014 | 08:32 PM
ralphobell's Avatar
The bearing is oiled from the diff fluid.
taylor15
May 5, 2014 09:27 PM
taylor15
Mar 10, 2013 09:46 PM
wheelgarage
Feb 21, 2012 11:39 PM
collin Barrows
Audio/Visual Electronics
Aug 21, 2011 12:47 PM
tskeltonPGA
Jan 16, 2008 07:21 PM
