front passenger window
i am thinking yes,,,
the good news is that it is maybe a 90min worth of wrench time and pretty easy to do.
i did my passenger regulator in January. ordered my new reg from atlantic british and installed it no problem. its pretty self explanatory once you have the door panel off. which is also pretty easy in itself
the rave should show you how everything is put together. really its easy,,, the door skin is held on place by some screws that are easy to spot. remove them remove the rubber strip that goes across the top of the panel where it meets the glass. and slowly work the door panel up and out of the door. unclip the wires to the speakers and window motor and the panel is off.
in the door itself you will see the regulator/motor and the bolts that hold it in place. get a flashlight and spend 5min seeing how it all goes together and you will see it is not a hard job. just have to think a little.
bcolins
10-02-2008 12:36 PM
