front passenger window
Old Aug 14, 2009 | 12:38 AM
caleb's Avatar
Default front passenger window
Hi i was wondering if my regulator is shot! my window goes down one inch, slightly crooked and stops. it will go back up but thats it --any ideas , thank you --caleb
Old Aug 14, 2009 | 12:48 AM
sloppyjoe's Avatar
i am thinking yes,,,
the good news is that it is maybe a 90min worth of wrench time and pretty easy to do.
i did my passenger regulator in January. ordered my new reg from atlantic british and installed it no problem. its pretty self explanatory once you have the door panel off. which is also pretty easy in itself
Old Aug 14, 2009 | 11:58 AM
oysterhead's Avatar
Does the RAVE manual describe how to get the door panel off?
My rear passenger lock actuator is out, and my driver door window rattles when I turn up the stereo. Not sure how to fix the latter?
Old Aug 14, 2009 | 12:04 PM
sloppyjoe's Avatar
the rave should show you how everything is put together. really its easy,,, the door skin is held on place by some screws that are easy to spot. remove them remove the rubber strip that goes across the top of the panel where it meets the glass. and slowly work the door panel up and out of the door. unclip the wires to the speakers and window motor and the panel is off.
in the door itself you will see the regulator/motor and the bolts that hold it in place. get a flashlight and spend 5min seeing how it all goes together and you will see it is not a hard job. just have to think a little.
Old Aug 14, 2009 | 12:07 PM
sloppyjoe's Avatar
and as for the window rattle,,,
it could be a loose bolt in the regulator assy, causing a rattle or check the trims around the window to see if there are some missing areas causing the window to not seal tightly
roverohio
May 22, 2009 11:17 PM
bcolins
Oct 2, 2008 12:36 PM
jwood700
Apr 17, 2008 07:03 PM
bobbydazzla
Apr 2, 2008 07:42 PM
suveer
Mar 11, 2008 04:38 AM
