front passenger window
Old May 3, 2010 | 07:49 PM
ace00959's Avatar
Default front passenger window
right front passenger on my 2001 discovery II will only roll up with help from a second person. It makes a buzzing noise when trying to roll up and sometime when rolling down it continues to roll down after window button is released. Does this sound like window motor or regulator? Can both jobs be accomplished without taking to a shop? Thank you in advance.
A.J.
Old May 4, 2010 | 08:20 PM
ace00959's Avatar
Anyone got anything on this? I could use some help. Thank you.
Old May 4, 2010 | 09:24 PM
david1289's Avatar
I would suspect that the regulator is not working right. You may not know exactly until you take the door panel off and see what's going on. I had a regulator get froze up one time...I thought it was the motor, but motor was fine...the gear mechanism on the regulator broke on mine and that was what was "froze".
Old May 4, 2010 | 09:54 PM
Antmen's Avatar
Yes, both/either job(s) can be accomplished without taking to shop.
I move slow and it took my 45 minutes to replace my regulator.
But as was mentioned, you won't really know until you take the door panel off
and, in some cases, remove the regulator/motor assembly for closer inspection.
-Anthony
roverohio
May 22, 2009 11:17 PM
bcolins
Oct 2, 2008 12:36 PM
jwood700
Apr 17, 2008 07:03 PM
bobbydazzla
Apr 2, 2008 07:42 PM
suveer
Mar 11, 2008 04:38 AM
