Front Prop Shaft U-Joints
Old Oct 11, 2012 | 10:17 PM
wreckdiver1321's Avatar
Default Front Prop Shaft U-Joints
What's the best grease to use for these? Mine need to be greased, as they haven't been in awhile. What do you guys use?
Old Oct 11, 2012 | 10:38 PM
I like the green colored synthetic grease, you can buy it at many parts stores and farm supply stores, it is also water and ferilizer resistant.
I just realized that in 10,000 miles the u-joints have been greased once. Is it just time to have the front propshaft rebuilt?
Old Oct 11, 2012 | 10:51 PM
Also, I have 3 grease fittings on mine. One on each joint. Do I need an upgrade?
Old Oct 11, 2012 | 11:49 PM
ScreamingLife's Avatar
I use termalene. Its kind of thicker, and I don't know where exactly to get it aside from military supply shop. They use it on rudders of submarines. Its excellent in water crossings.
Old Oct 12, 2012 | 06:25 AM
coors's Avatar
Military grade lube. Nice.
Old Oct 12, 2012 | 07:15 AM
Just buy the best grease you can and it should be synthetic.
Also, you should have a total of 6 or 7 fittings and grease them twice a year or at every oil change.
Old Oct 12, 2012 | 10:29 AM
Thanks guys. And Mike, if I don't have that many fittings, is it probably time to get a new shaft?
Old Oct 12, 2012 | 10:59 AM
Here's pix of the part where the extra fitting are usually missing from the factory on the front shaft. You can rebuild it, have it rebuilt, or buy a new one. If you just have a patio and a couple of hammers it may be time to farm this job out.
Old Oct 12, 2012 | 11:20 AM
br0keit's Avatar
You should have 1 per u-joint (3 front, 1 rear) and 1 for each slip joint (1 per shaft)...so that's 6 total unless I forgot one somewhere.
