front and rear bumper trimming/rocker panel plastic removal
Old Jul 18, 2011 | 10:22 PM
frat daddy's Avatar
Default front and rear bumper trimming/rocker panel plastic removal
anyone done this or anything like it? my plans are to trim the lower corners below the fog lights off of each side of the front bumper (only reason being that's the most common rub spot), remove the plastics from the rocker panels, and trim the corners of the rear bumper that hang down. the red line in the pictures will probably explain it better. haha has anyone done this or anything like it? i personally think it will look a lot cleaner and it will also have less plastic to break in the woods.. plus i just dont like having all the plastic
positive feedback only please..
Old Jul 18, 2011 | 10:25 PM
frat daddy's Avatar
btw the trim on the doors has been removed... the pic was taken when i was in the process. thats why the front piece is sticking out
Old Jul 19, 2011 | 12:07 AM
yloDiscoII's Avatar
For DI guys, trimming the front bumper is very common, so you might see more examples if you search there.
I've never seen the area below the doors trimmed, as there isn't a whole lot of room to trim, plus it seems that if you trim there, you would lose your splash guard, and you'd have issues with wet roads kicking up water inside. Maybe I'm way off. I've got rock sliders and they are great, they work great and offer a step for the wife.
The only time I've seen the rear quarters trimmed is when a steel bumper (Like a Greg Davis or Rovertym) is added.
I say more power to you, just measure twice, cut once
Old Jul 19, 2011 | 12:38 AM
bosshogt's Avatar
I would say trimming the rear bumper lower section would be a good idea. You might want to buy a Dremel MultiMax. Great plunge oscillating tool. It will cut plastic cleanly.
I have one and have used it a ton of times, for car projects.
Trimming the rear fender would be a good idea. But you may want to consider a steel wrap bumper to protect lower fender.
I would skip trimming the plastic sides. Save your money for steel sliders.
Old Jul 19, 2011 | 07:42 AM
JavaRacer's Avatar
Default GO for it
The plastic sides are just trim pieces and easily removable with screws, so go for it! I removed mine when I got my rock sliders. If you don't like it, just hang on to the mounting hardware so you can reinstall them. In fact, I still have mine in the garage, just in case...
Old Jul 19, 2011 | 08:50 AM
hilltoppersx's Avatar
when my truck was nearly stock i had trimmed the front bumper. i used a sharpened soldering tip. the rear bumper you can trim and the rear quarter panels you can trim (to make it a straight line). the door sills you can remove the plastic trim but i wouldnt cut the metal there.
Old Jul 19, 2011 | 12:40 PM
frat daddy's Avatar
that was my plan... i will only trim the front and real bumper. i will just remove the plastics under the doors until i can afford some sliders. is there not a rocker panel under them??
Old Jul 19, 2011 | 12:41 PM
frat daddy's Avatar
thats the exact look I'm going for on the front bumper.. that also eliminates the common rub spot for front tires too correct?
Old Jul 19, 2011 | 01:38 PM
yes there is a rocker panel. i have the plastic still on, that way when i hear the crunch i know im close to destroying things i don't want to destroy. yes the trimming helps the approach angle.
Old Jul 19, 2011 | 02:26 PM
frat daddy's Avatar
i just pulled the small plastic piece off the bottom of the rear quarter... i think i will use the cut and fold method to trim it to form the straight line. assuming i do it correctly, it should look like everything came from the factory that way
bcolins
Jun 22, 2013 08:55 PM
russdouble
Feb 5, 2011 12:43 PM
pilsner
Dec 7, 2008 03:39 PM
LRDISCO
Sep 11, 2008 09:37 AM
Disco2Guy
Mar 24, 2008 11:14 PM
