front right sensor output low
Old Jun 7, 2009 | 04:12 PM
grendel's Avatar
Default front right sensor output low
Recently replaced my right front wheel sensor to clear the two error codes:
064 front right sensor electrical fail
044 front right sensor output low
Unfortunately the 044 error codes is still there. The 3 amigo lights come on after the truck exceeds 10 mph. Is there a fix for this error code? What should I do next?
Russ
Old Jun 7, 2009 | 04:16 PM
gilder's Avatar
Have you followed the cable back to the module to see if it is nicked or kinked?
Old Jun 7, 2009 | 04:29 PM
grendel's Avatar
I checked the cable and it seems fine.
Old Jun 7, 2009 | 04:56 PM
gilder's Avatar
Do you know where the ABS module is under the hood? Should be on the driver side by the shock tower. If you look at the top of it, do you see a barcode?
Old Jun 7, 2009 | 05:02 PM
grendel's Avatar
Here are the barcodes:
SRB-101241-01-007339
478-407-020-0
003-2001
007339
Old Jun 7, 2009 | 06:33 PM
gilder's Avatar
Well, if you have barcodes on it, you have the "correct" abs module. Not sure what else it could be unless the cable needs to be replaced. Need someone younger and brighter in on this one....
Old Jun 7, 2009 | 07:26 PM
grendel's Avatar
My local LR dealer suggested I replace my aftermarket slotted rotors with factory ones. Has anyone heard of this before?? Not sure how the rotor will affect the ABS sensor.
Already replaced the shuttle valve, so I'm running out of ideas.
Russ
Old Jun 7, 2009 | 07:35 PM
ryanD2's Avatar
Do you have a DMM?
Old Jun 7, 2009 | 07:44 PM
grendel's Avatar
What's a DMM?
Old Jun 7, 2009 | 07:55 PM
ryanD2's Avatar
digital multimeter, or a multimeter that reads ac voltage.
