Front sits lower than rear 04 Discovery
New to me 2004 Discovery 2:
ARB bull bar with winch
ARB sliders
OME HD lift with OME nitro charger sport shocks.
The vehicle sits with a noticeable rake with the front sitting lower than the rear. The on-road handling is fine but off road or over bumps very stiff ride. That’s to be expected I guess with the HD lift. I was thinking about adding shock isolators to raise the front a bit but I’m worried about making a jarring ride even worse. Any input would be appreciated. Any way of softening the ride a bit? I realize I’m probably stuck with the HD springs due to the weight up front.
ARB sliders
OME HD lift with one nitro charger sport shocks.
The vehicle sits with a noticeable rake with the front sitting lower than the rear. The on-road handling is fine but off road or over bumps very stiff ride. That to be expected with the HD lift. I was thinking about adding shock isolators to raise the front a bit but I’m worried about making a jarring ride even worse. Any input would be appreciated. Any way of softening the ride a bit? I realize I’m probably stuck with the HD springs due to the weight up front.
So if I put in the coil spacer would the quality of the ride decrease? Would there be any driveline, brakeline / Abs line or steering linkage issues that would need to be addressed?
Sixpack577 (11-06-2019)
