Front / Timing Cover Leak / Replacement
  #21
Old 02-02-2012, 06:00 PM
bosshogt's Avatar
I think those are inspection plugs for your flywheel. You can find plugs like that in the plumbing dept at any hardware store. You can probably get them for $15 or $20 at the dealer. Or $2 at the hardware store.
  #22
Old 02-02-2012, 07:45 PM
MrFlea1's Avatar
Originally Posted by MattyMatters
Can any1 tell me what these two holes in my oil tank are for and where I can find a replacement gasket for the one side?
As I dropped the oil tank/pan, i noticed the one rubber seal was shredded and unable to be reused.
Thanks,
Matt
Flywheel/convertor bolt access holes. grommets are dealer items $12. each. They swell up from oil deposits and are a byach to try and replace unless you use new.
  #23
Old 11-17-2016, 04:39 PM
Chris Faronea's Avatar
I'm Assuming by now (4 years later) you've got this figured out. For anyone else running into this problem, put a socket on the Crankshaft nut and rested to wrench handle on the driver side frame using a cheater bar and just barely bumped the ignition. A quarter of a turn to break the seal and then it came off by hand super easy. I understand this a last option, but it worked beautifully for me
A5scott
07-11-2015 07:25 PM
7smoothoperator7
10-19-2014 07:09 AM
tmtegt
03-20-2013 07:31 AM
neroverguy
08-19-2010 12:58 PM
Quick Reply: Front / Timing Cover Leak / Replacement
