Front timing cover part number questions - two different numbers
Old Aug 15, 2025 | 11:40 AM
T-rex's Avatar
I cleaned up the area right under the pulley before testing. If the video doesn't work, I tested with the glove, it sucked it in, and a new drip of oil started after a couple revs.
File Type: mov
Old Aug 17, 2025 | 07:12 PM
Extinct's Avatar
Well having vacuum is good, so it is either coming through the ID, OD, or the cover. I have seen some cracked covers because of broken oil pumps. If it is coming through the ID, likely damaged surface on the balancer shaft. To seal the od, coat the seal with a thin layer of silicone before driving it in.
Old Aug 18, 2025 | 12:31 PM
T-rex's Avatar
Last go around I really took my time and cleaned all the surfaces and added a thin coat of oil resistant silicone around the OD. I also pressed in the seal using the pulley bolt rather than tapping it in with a hammer. I got the speedi sleeve in today hopefully that will do the trick, but I still think it's the cover. I'll really celebrate if it takes care of the problem.
Old Aug 19, 2025 | 04:09 PM
T-rex's Avatar
Speedi Sleeve for the win. I've never been happier to be wrong about what was going on. I really, really, really didn't want to have to pull the cover.
THANKS TO EVERYONE for the suggestions and help pointing me in the right direction!
Old Aug 19, 2025 | 05:51 PM
Brandon318's Avatar
Speedi Sleeve is the GOAT. I'm a two is one, one is none kind of guy, so ended up buying another SS for the future just in case they ever stop making it.
neuropathy
Sep 13, 2022 12:45 AM
mike.alizadeh@gmail.com
Range Rover Classic (1st Gen)
Feb 12, 2020 04:44 PM
Scott Weiland
Jul 18, 2019 08:39 PM
shanechevelle
Nov 4, 2011 06:29 AM
possibly owner
Aug 19, 2009 01:45 PM
