Front two o2 codes still lingering, any ideas?
I had 5 oxygen sensor codes, but after replacing all 4 o2's, i'm down to just the front two codes (0134, 0153). Front two were replaced (AB sensors) about a week before replacing the manifold to y-pipe gaskets (was missing 3 of 6 total studs between the two sides and the gaskets were toast).
Anything else that could throw these codes? I do believe the front two aren't working properly either way, because I get around 8 mpg's these days and it smells like it running a little rich or something.
Thanks in advance.
Thanks in advance.
I did clean the area and connection and used that CRC electric cleaner stuff as well...maybe just not good enough? I'll let you know when I get the new ones if it solved the problem.
me 2
11-27-2012 08:09 AM
bocamar
02-26-2011 08:47 AM
