Front Wheel Bearings -- What else?
Old Feb 24, 2019 | 11:19 AM
Saturnine's Avatar
Default Front Wheel Bearings -- What else?
Right, ordered new bearings last night -- yay
Also need new axle nuts and o rings along with a 1 1/14 socket?
Questions:
Rear hub o ring is the same as front, jah? AB Rear Hub O Ring
Axle nuts -- $10 each?! Or are Britpart bits ok? AB Axle Nut
Torque spec is 250-360 in rave / bulletin but which is correct?
Old Feb 24, 2019 | 12:14 PM
Friday Night Disco's Avatar
Front O ring is different size
Old Feb 24, 2019 | 01:42 PM
The Deputy's Avatar
Front hubs don't use o-rings...they have seals within the axle housing. Most hubs contain new nuts.
​​​​​​​ Brian.
Old Feb 24, 2019 | 01:44 PM
OverRover's Avatar
No O ring in the front, a SEAL is used FTC4822. See video for install.
The Hub/Axle Nut (CDU1534L) is 32mm & IMHO forget $hitPart.
360 lbf.ft is spec. Good Luck with that.
Old Feb 24, 2019 | 08:32 PM
Old Feb 24, 2019 | 09:37 PM
Best4x4's Avatar
I always remove the center cap & loosen the nut with the wheel still on the ground.
Old Feb 24, 2019 | 10:29 PM
yeah, I was wrong
Old Feb 25, 2019 | 07:26 PM
Twix's Avatar
Get yourself a 4-6 foot breaker bar.
Old Mar 3, 2019 | 12:54 PM
Saturnine's Avatar
Got the bearings the other day, hopefully going to install them sometime this weeks. Haven’t checked to see if they came with axle nuts, but I’m kinda doubting they did
nickm347
Dec 6, 2016 11:08 AM
TRIARII
Oct 4, 2014 09:19 PM
tooltech
Oct 29, 2012 11:03 PM
GROVERtheROVER
Aug 29, 2011 09:37 PM
waynehicks
Aug 2, 2009 10:36 PM
