Front Wheel Shake/Wobble
Old Feb 15, 2010 | 09:51 AM
kenk's Avatar
Default Front Wheel Shake/Wobble
OK, I've been trying to track a problem with my drivers side wheel shaking/vibrating. I have so far replaced, as they were needed anyway, tie rod ends(all 4) swivel bearings,bushes,pins(not done by me,and double checked to make sure they were set up right), shocks are <1yr old. Rotated that tire to eleminate an out of balance issue. Radius arm bushings look new with no slop at all. Wheel bearing checked and repacked. I can not visually see the panhard rod bushing condition, but I get no movement at all when trying to wiggle it in any direction.
Before the tie rods and swivel bearings, I could get slack/movement by wiggling the wheel when jacked off the ground. That is gone now, and the shake/vibe is much better, but still there. It only happens over 55-60mph and usually when turning or when i hit a bump.
So what I'm thinkin is- I bought Explorer Pro-Comp shocks, which I thought were ok shocks, but many told me thet pretty much suck. Could that one have gone bad in less than a year? I am running Bearmach HD springs. Maybe that accelerated the shock goin bad?
The only other thing I can think of is the sway bar end link bushings look shot, but I dont know this to be a symptom of that. Am i wrong?
aBs0lut30
Mar 31, 2015 10:43 AM
bradman951
Apr 14, 2014 10:10 PM
jeffh
Jan 20, 2011 12:35 PM
Spencerfitch
Jun 26, 2010 11:02 PM
Andy Tracey
Apr 1, 2007 12:18 AM
