Front Windows stopped. BCU??
If your BCU ends up being the culprit then you may want to consider a professionally reprogrammed BCU unit that is programmed in advance and shipped to your door, ready for installation. Based out of the UK. Call them or fill out the contact form. Cheaper than new unit but better than using an old used unit.
Turner Diagnostics:
https://www.turnerdiagnostics.com/la...-exchange.html
Turner Diagnostics:
Update on this issue, I swapped out both ECU and BCU. Afterwards the vehicle will not start. All I get is a flashing odometer. Unless both the used ECU and BCM I have are toast, merely swapping parts is a no go on this vehicle. Possibly both would have to be re flashed by the dealership?
When you swap the ECU/BCU the Rover is immobilized.
You need to use the EKA, or turn the key in the ignition to the 2nd position and leave it for 5 minutes to sync.
I would look into the motor as the culprit. It seems more likely the window motor went out than the BCU.
Thanks for that info, Nick. Is it common for both motors to fail at the same time? Exactly the same time?? Both windows worked fine a few time earlier in the drive. The last time I sent them up, the passenger side went all the way up, the drivers stopped prematurely. Now, neither side will do a thing. Not saying it doesn't happen, just seemed a bit odd.
As a side note, per TRIAR11's suggestion, I talked to Turner Engineering this morning. Nice fella, very helpful too. If I do determine I have a bad BCU, I may send both to have them repaired. No harm in having a spare.
Sixpack577 (09-08-2017)
Sync the new ECU/BCU by leaving the key in the 2nd position for 5 minutes and see if that changes anything.
Cheers and good luck.
PS: Im going through same **** with my front windows too. Except my front driver motor and regulator are new, all the fuses and the relay are good. I feel your pain
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
Tried swapping out the new/used BCU this morning and went thru the minimum 5 minute wait before trying to start the truck.
Nothing changed with the windows and the truck will start and then shut down.
Looks like my next step is to get one or both of my BCU reprogrammed in the U.K. Or...... can a dealership do this. I believe the closest to me is in Atlanta, about 2 hrs north
LandRover of Buckhead
3040 Piedmont Road NE
Atlanta, GA 30305
Any Georgia members have any experience with this dealer ?
Atlanta, GA 30305
