Front Wipers: new motor, new switch...still no intermittent or slow
Old Jun 4, 2016 | 08:11 PM
ge234's Avatar
Default Front Wipers: new motor, new switch...still no intermittent or slow
I realize this is a tired topic but I'm out of options-sorry to bring it up again...I've even checked other forums [gasp]
Last winter the slow and intermittent settings stopped working. After reading on here that switches go bad I removed mine and cleaned it. Put it back in, no dice. Bought a new (used) switch, installed...still no dice.
Today I installed a replacement motor thinking the slow speed brushes were worn out. (common problem according to forums). The replacement motor worked identically to original.
I hear a faint tick when I engage the wiper lever/switch, does this indicate anything about the switch? What am I missing? Is there a relay?
Old Jun 5, 2016 | 02:58 PM
squirt's Avatar
9 times out of 10, it's old, dried grease in the switch inhibiting contact. I can almost guarantee that your original AND the used replacement have the same issue.... These trucks are old enough that they all have the issue unless it's already been fixed.
See this thread...
https://landroverforums.com/forum/di...tch-fix-46886/
Old Jun 5, 2016 | 03:31 PM
NickAdams's Avatar
I agree. I have no experience in this area, as I have not yet had this problem with the Disco. But squirts' comments above reflect my initial reaction; and note: he has been a member of the forum for 8 years.
Old Jun 5, 2016 | 04:07 PM
number9's Avatar
Test low speed brushes prior to install?
Old Jun 5, 2016 | 08:34 PM
ge234's Avatar
Default will clean the switch...again
thank you for the feedback...i cleaned the switch once but may not have done it properly or thoroughly enough. will update back when i can.
Old Jun 6, 2016 | 12:06 AM
squirt's Avatar
For what it's worth, I've done this on probably half a dozen trucks. It has worked every time. Disassemble the switch to completely expose the contacts and use a scotch brite pad with some electronics cleaner to get all the old crusty stuff out. Do a thorough job and it will be good for the next 15 years.
bigbalu
Dec 4, 2014 02:13 PM
Sinner
Dec 11, 2013 11:19 AM
grandkodiak
Mar 6, 2013 05:35 PM
PJH
Jan 10, 2012 06:19 PM
wblake
Oct 24, 2007 08:32 PM
