fuel capacity
Old Apr 23, 2007 | 05:40 PM
apcollin's Avatar
Default fuel capacity
I have a 96 D1 SE7 (manual), and have read that the fuel tank capacity is around 23 gallons.
However, if I fill it up when the needle on the gauge is around "E", it only takes about 15 gallons!
Is my gauge inaccurate, or is the tank smaller than I thought?
Old Apr 23, 2007 | 05:45 PM
bamarover's Avatar
Default RE: fuel capacity
i am not sure, i read on here that you had 23 gallons. http://www.edmunds.com/used/1996/lan...566/specs.html
Did the previous owner replace the gas tank?
Old Apr 23, 2007 | 08:12 PM
I believe the D1 has a smaller tank then the D2 but I don't remember what their size is.
Mike
Old Apr 24, 2007 | 12:18 AM
StevenDiscoII's Avatar
Disco I- 89 liters = 23.5 gal
Disco II - 93 liters = 24.6 gal
Old Apr 24, 2007 | 07:40 AM
benfbi's Avatar
I have a 93 Disco with a 3.5L V8i and my book says 81.5 liters or 18 gallons.
Old Apr 24, 2007 | 10:43 AM
Where are you located benfbi ? From my recollection, therewere no 3.5 L models imported to North America. The first ones were model year'94 with 3.9 L V8and fuel tank cap. of 89 L.
Old Apr 30, 2007 | 05:29 PM
apcollin's Avatar
Yes, I keep finding that 23.5 gallons is the number for the D1.
however, i recall the previous owner saying the gastank had been replaced.
Looks to have an 18 gallon capacity. Any idea what vehicle this could be from?
Old Apr 30, 2007 | 06:20 PM
okdiscoguy's Avatar
Car Fax should tell you. I have a 97 SD-7 and I have a 23 gallon tank.
Old May 1, 2007 | 12:59 AM
deuteronpsi's Avatar
on a related note, suddenly I can't get my Disco II to "fill up". I let it go down to empty and the fuel warning light comes on. I put gas in it and only get to about 16 gallons before the fuel pump cuts me off because of the back pressure. My fuel gauge shows me as having about 3/4 of a tank but I can't force any more in so it must be full.
Old May 1, 2007 | 11:28 AM
Sounds like your fuel level sensor in the tank may be failing. Check you miles driven before refilling and see if you are only driving the eqivelant of only 16 gals or 24.
Mike
Broken08
Feb 8, 2015 01:50 PM
1danger1
Apr 21, 2013 03:46 AM
sdyver
Jan 5, 2013 02:01 PM
camrover
Defender
Jul 2, 2012 03:00 PM
bigugly82
May 17, 2007 09:30 AM
