Fuel door not opening
Old Oct 30, 2021 | 03:29 PM
Eutopia's Avatar
Default Fuel door not opening
Hi , when I push the fuel door button is not opening , does anyone know what fuse controls the latch ? or any other problems that I might have ? 2000 disco . Thanks
Old Oct 30, 2021 | 06:03 PM
SundayFunday's Avatar
Is ignition off?
mine will not open when truck is running.
Old Oct 30, 2021 | 10:24 PM
Eutopia's Avatar
Originally Posted by SundayFunday
Is ignition off?
I tried everything , off , on , pushing few times fast , holding .....not opening
Old Nov 2, 2021 | 09:15 AM
Sandman614's Avatar
More info is needed. Do you hear it trying to open?
Old Nov 2, 2021 | 10:15 AM
Externet's Avatar
Try pushing the door gently in while someone hits the dash button. Sense if there is actuator motion. If no action, check electrical; disconnect and feed 12V to the actuator somewhere else in its vehicle circuit.
Old Nov 2, 2021 | 02:43 PM
Harvlr's Avatar
Otherwise you may need to open the right rear interior panel to access the mechanism to open it and then figure out what’s gone wrong.
neuropathy
Aug 7, 2022 09:36 AM
chubbs878
May 12, 2015 10:42 PM
frabal
Sep 13, 2012 10:47 AM
Zagorfly
Oct 24, 2010 10:17 AM
nynole
Feb 14, 2008 05:21 AM
