fuel door release switch
Old Apr 20, 2009 | 09:44 AM
Rover Chris's Avatar
Question fuel door release switch
OK guys I have been thinking about this since I bought the truck. wiring a switch to an actuator behind the rear bumper that is attached to a rod that goes up to the fuel filler door and then spring loading the rod and the door hinges thus giving me a fuel door release switch. I know it does not sound like much but I hate the fact that I have to grab my 1 key for the fuel door (which I keep above the ashtray) every time I need fuel, feel free to call me lazy at this point. I do like that my fuel door is secure (especially with todays economy and often changing fuel prices) but would prefer a button on the dash to pop it open. just wondering if anyone has ever done this or considered doing it?
Old Apr 20, 2009 | 10:30 AM
AvsRover2000's Avatar
Would it be possible to put in a DII release button and door actuator?
Old Apr 20, 2009 | 10:55 AM
that's what I would do I no longer have a factory radio so the instrument cluster bezel switches for the radio can be replaced with whatever I want, my concern however would be to make this thing work on the fuel door side. I have looked closely at it and I think the best solution would be to modify the latch part on the truck and shorten the bar that goes up and down on the keyed part (this way the key would still work if needed). as for the catch on the truck side it is like a triangle I am thinking if I was to replace this with a small flexible plastic tab (unless I can find a small pre-made spring loaded release mechanism for cheap) and a small metal cable (like a bicycle brake cable) then I could have the actuator pull the plastic tab back and allow the shortened bar slip past it and open the door, and to make this even easier the door is already spring loaded!!!
I have an old actuator that will work fine now I just need a few other parts.
NENYMA
LR2
Dec 22, 2016 12:43 PM
vic_lagina
Aug 6, 2015 06:54 AM
rckign323
Jun 6, 2013 09:52 AM
paul1454
Aug 28, 2010 02:01 PM
ericlt
Apr 28, 2006 07:01 PM
