'02 D2 Fuel Door Release Actuator
Old Aug 4, 2015 | 02:35 PM
vic_lagina's Avatar
3rd Gear
Default '02 D2 Fuel Door Release Actuator
Hi All,
I have an '02 Disco II. The fuel door lock/release rod grommet has disintegrated and the rod has fallen into the body.
I have ordered the new grommet but I cannot figure out how to retrieve the actuator from inside the body. I removed the inside panels but this didn't give me access to the actuator. I looked under from outside and saw the fuel door but still no actuator.
Can anyone tell me the best way to retrieve this from inside the body?
Old Aug 4, 2015 | 03:36 PM
Joemamma1954's Avatar
the actuator is bolted to the body. Did the rod fall down or what? We recently replaced my son's and got to it though a hole behind the panel real close to the back.
Old Aug 4, 2015 | 03:47 PM
vic_lagina's Avatar
3rd Gear
Good point, it is just the rod that is missing. All that is there now is the empty hole where the rod and grommet used to live.
Old Aug 4, 2015 | 04:09 PM
We got one and i think the rod was attached to the actuator, I will look at the one we removed and let you know. By the way the new one did not work either, it is not getting power, will have to dig further.
Old Aug 5, 2015 | 04:29 AM
vic_lagina's Avatar
3rd Gear
I know that the actuator is getting power as I can hear it working when I hit the switch in the cockpit.
Old Aug 5, 2015 | 11:15 AM
I looked for the old actuator, and my son must have it. Your rod became unattached from the actuator and you will need to remove the actuator and retrieve your rod and see if it actually broke or can be reattached. If you cannot get your rod out, you only option may be get another actuator. Have seen them on eBay.
Old Aug 5, 2015 | 01:13 PM
jamestfl's Avatar
Mine had just fallen in that tiny space between the fuel line and body panel. Very small, very dark. Maybe take a look. Who'd you get the grommet from?
Old Aug 5, 2015 | 01:22 PM
Externet's Avatar
Try a magnet very attached to a coat hanger wire to attempt fishing it out. The body being aluminium may help in avoiding sticking there; but not to other iron parts that may be in the way.
Old Aug 6, 2015 | 06:54 AM
drowssap's Avatar
i got tired of replacing that plastic clip and epoxied a magnetic cabinet lock inside the fuel door.
expedio2005
Oct 4, 2019 01:57 PM
roverroveroverthere
Apr 23, 2012 10:22 AM
airmarc
Jan 11, 2012 12:01 PM
renfield
Dec 18, 2011 01:31 AM
Rover Chris
Apr 20, 2009 10:55 AM
