Fuel to Engine Issue
Okay, I spoke to soon stating I had fixed my problem that is outlined in this thread. (https://landroverforums.com/forum/di...g-issue-59854/)
I got in the vehicle this morning and it fired right up. I made it to my destination and when I went to leave the truck started and then choked down. Upon inspection I noticed that a hose had slipped off the newly installed fuel pump. I proceeded to clamp the hose and reinstall the fuel pump. Now after the car sits for 30 minutes or so it has a hard start issue. It cranks during the first turn but will not actually start until the second or third turn of the key. Is it possibly a defective fuel pump or is there another issue?
I have looked into the Rave manual regarding the fuel system and cannot locate a check valve in the line. I do know pressure is being maintained at the fuel pump because I have since disconnected the fuel line and when I did it "shot" fuel out.
Thanks in advance for any insight you are able to provide.
Travelor
09-24-2015 06:11 PM
cobbcj7
03-23-2015 07:07 PM
JumPeR04
04-07-2011 09:52 PM
atikovi
04-07-2007 03:27 PM
