Fuel gauge not accurate
Old Jul 12, 2023 | 10:11 AM
redrover75's Avatar
Default Fuel gauge not accurate
My fuel gaige has not been accurate lately. I just replaced the fuel pump, no better.
I was just below the halfway mark and it took 18.9 gallons. I have been reseting the trip odometer and filling about 220 miles. Strangely it seems to become more accurate the lower it goes. It seems the light comes on at the appropriate level. So sometime between half and nearly empty it corrects the read out.
Any ideas on what else could be causing the incorrect read?
Old Jul 12, 2023 | 10:23 AM
BillF's Avatar
4wd High
Maybe the sending unit in the fuel tank
Old Jul 12, 2023 | 10:36 AM
ahab's Avatar
The fuel gauge is driven by resistance to ground across the sender. If you have a poor connection in the wiring somewhere it will affect the reading that even a new pump will generate (I assume you got the pump/sender assembly and not just an actual pump). I haven't checked the ETM to know where the pump is getting its ground but it might be worth a look.
Old Jul 14, 2023 | 04:02 PM
Discorama's Avatar
It seems to be a general issue with Discos. Many here have reported an inaccurate fuel gauge. My gauge is at exactly at half when 10 gallons are left only. When I top it up to the click of the pump I can drive 60 miles before the needle gets down to the full mark. It has been that way since I bought my Disco 6 years ago.
Old Jul 14, 2023 | 05:43 PM
Best4x4's Avatar
When installing the fuel pump you must get it seated into the little circle at the bottom of the tank. If it's not seated you can still get the pump to push down, but since it's not centered = fuel level readings are off. I'd personally try centering it again and see if it changes.
Old Jul 15, 2023 | 08:22 AM
redrover75's Avatar
Default Alignment
That would make sense. In other cars there was a twist to lock the pump in place. I did not see or feel that in the Rover. There was nothing to ensure it was in the right place other than the compression of the gasket and the springs. Ill have to dig into it again.
thanks
redrover75
Jun 23, 2020 11:48 AM
glennforbes@rocketmail.com
Jan 31, 2020 11:15 AM
CollieRover
Nov 29, 2018 09:37 AM
Dwimmerlaik
Apr 26, 2012 04:05 PM
40ranger
Apr 7, 2008 12:20 AM
